Nobimmer 694 Report post Posted March 1, 2010 Need a front sway bar + links for a 325 E30. factory (bigger one) or aftermarket. Need fairly soon. Cheers Ashkan Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted March 1, 2010 buuuump Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted March 1, 2010 Hi, got one give us a call on 04 3801089 cheers Jon Quote Share this post Link to post Share on other sites
HELLBM 1697 Report post Posted March 2, 2010 Can do. 0212435526 Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted March 2, 2010 be careful about going too stiff in the front. The stiffer your anti-roll bars in the front the more understeer you will promote. You can also decrease the turn in of the car with stiffer rollbars. I know a bunch of people that run smaller than factory anti-roll bars, or no anti-roll bar and they prefer the handling of the car that way. Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted March 2, 2010 We're not talking about some French chassis made of cheese here Heath It's common practise for guys serious about driving their E30's to upgrade to the M325 front sways Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted March 2, 2010 Simon - if the french cheese chassis was so soft then why is they that they don't need the extra stiffness in the front? It's more likely that the limp bratwurst of a E30 chassis needs the extra stiffness to make it handle better... Thats all good then... it's just something to keep in mind. probably comes down to how you like your cars setup also. Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted March 2, 2010 Comes down to technique then I guess - glooping round corners like runny Brie Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted March 2, 2010 yup... Quote Share this post Link to post Share on other sites
mitchE30 0 Report post Posted March 2, 2010 BMW is and understeer RWD. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted March 2, 2010 ^ WTF are you on. Quote Share this post Link to post Share on other sites
mitchE30 0 Report post Posted March 2, 2010 ^ WTF are you on.6 cylinder E30 most like to understeer. Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted March 2, 2010 Bhahahahah BMW is and understeer RWD. Ray, will ring you tommorow. Can't really get out to ya till Friday. Heath- Cheers for that, have read that with a decent spring rate and stiff as sways,it will understeer. I think that Henry ran into the same problem in his build. Standard/m325 one will do for now. Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted March 2, 2010 From what I have learnt since putting big bars on, it was the speed at which I was moving the steering wheel which was causing the understeer. Slowing down the wheel and turning in beautifully and smoothly cured all ills, it takes a little while to really sort it out. Also, the margin of warning (the feeling of tires just starting to let go) to the grip letting go at both ends is nearly non-existant, great fun in the wet with R888's. The difference with the bars on the track was amazing, need 50% harder springs now hahaha before. grip>>.................................warning..........lets go |..................................................|...............| Now: grip>>..................................................WARN-LETSGO |...............................................................|...| So just steer smoothly. Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted March 2, 2010 Sweet, cheers for that mate. Will look into it after I sort the brakes out and get it on the road. Just want to get the bloody thing out of the shed! Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted March 2, 2010 something to keep in mind. whats the o.d. of the factory fitted bar, whats the o.d. of the 325 bar. Hollow? Solid? have a read of this more so for the graph to give you an idea of what going up 1 or 2mm in bar dia will do to overall roll stiffness: Visit My Website A track will always better suit a stiffer car. The pug boys for road rallys will run a 24mm rear anti-roll bar and 21/22mm torsion bars. The dedicated track boys will run 28mm rear anti-roll bars (ones running 30mm) with 24-26mm torsion bars... As there is not bumps, dips, unulations, etc... Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted March 2, 2010 (edited) I went from 320 front sway bar and no rear bar to M325I ( don't know if M or not makes any difference ) front and rear with urethane bushings on the front and the difference was really really good it went from loose and floppy to crisp and good Edited March 2, 2010 by Jimmy Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted March 2, 2010 I went from a 20/21mm front factory 325i bar to a 24mm whiteline bar and the difference was amazing, that coupled with urethane sway mounts alround and it felt like a different car. Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted March 2, 2010 not saying you guys don't need it... just letting the dude know the theory. I was also trying to highlight the difference in setups for track vs road. Forrest what did you do to the rear? I didn't realise that the E30's where that soft in the front to start with. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted March 2, 2010 Just factory rear bar with urethane mounts Quote Share this post Link to post Share on other sites
