bravo 35 Report post Posted February 7, 2005 (edited) I want to put driving lights in the factory location in the front valance. What ones fit? Can someone give me a part no.? Or dimensions? Thanks Edited February 7, 2005 by bravomikewhiskey Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted February 7, 2005 01 FOG LAMP LEFT 1 09/1987 63171385945 01 FOG LAMP RIGHT 1 09/1987 63171385946 foglights Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted February 7, 2005 Cheers - where can I buy some (other than BMW). Does anybody have any in need of a good home? Quote Share this post Link to post Share on other sites
CaM 0 Report post Posted February 7, 2005 you can get them through hella, unfortunatly i don't have the book with the e30 stuff, just finished up my job, so yeah, only have the main NZ catalogue and the non-oe "styling" catalogue which doesn't really cover e30s...... haha shoulda done a mission to get the full lighting catalogue, nobody else ever used it........ but yeah, hella, they make the o.e stuff... :bounce: Quote Share this post Link to post Share on other sites
Hartage 0 Report post Posted February 7, 2005 Are you looking for F/L or pre F/L lights? Am dismantling a Pre F/L 323 now! Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted February 7, 2005 F/L dammit. Quote Share this post Link to post Share on other sites
Hartage 0 Report post Posted February 8, 2005 Bugger Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted February 8, 2005 Ollie got them new from hella - they just plug in. Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted February 9, 2005 well not exactly. i got a set of foglights new from hella at cost, approx $230 for the set. they are slightly bigger than the holes for them but fit neatly in behind them. i had to drill my own holes to mount them and crimped the wires to make my own connection, but yes the wiring was ALL there. Quote Share this post Link to post Share on other sites
petone 0 Report post Posted February 10, 2005 All the wiring is there. You just need the switch and the relays to plug into the fuse box. You may also need the bulb that goes into the dash. If you do it that way it will be the same as factory. Also, there is sort of a pre-facelift facelift. The early E30's (85 or earlier) have a different front lip arrangment. (this has something to do with the brake ducts) although the foglights are the same the brackets that hold them in are different. Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted February 10, 2005 although the foglights are the same No they are not. The fogs are completely different between Pre F/L & F/L Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted February 10, 2005 graeme petone was talking about a variation of pre facelift Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted February 10, 2005 My bad Quote Share this post Link to post Share on other sites
