tire 10 Report post Posted March 9, 2010 (edited) Car is a 1990 325i touring automatic. 1. There''s these 2 wires both sides of my engine bay that have been clipped, the part number brings them up as being for a 'pulse generator' - diagram'. What do these pulse generators do / how important are they? I'd never heard of them before. 2. Is the fuel filter mounted somewhere abnormal in facelift 325i auto tourings? Cause I just noticed today that mine doesn't have one in the usual place (see pic). 3. Are the headlight squirters and wipers supposed to operate with the main ones? 4. Whats the go with fitting mt1 fron't and back to facelifts? Cheers Edited March 9, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted March 9, 2010 Fitting Mtech I kits to facelift cars is a pain. Get the angle grinder out and start sawing sh*t. The headlight wipers only work when the headlights are on. And only once every 30 seconds. Turn the lights on and then pull the windscreen wash lever. If nothing happens the headlight wipers are screwed. 99% of them are anyway. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 9, 2010 (edited) (1) ABS speed sensor wiring (if fitted) (2) Under the car in the rear (3) Only when the headlights are on and you use you windscreen washers (4) Others may be able to help with this one Edited March 9, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted March 10, 2010 4. Whats the go with fitting mt1 fron't and back to facelifts? Cheers Front - not a problem. Rear - as said, get out your angle grinder! Quote Share this post Link to post Share on other sites
tire 10 Report post Posted March 10, 2010 Sweet, sorted. Thanks all! Quote Share this post Link to post Share on other sites
