kiwi6539
Want to increase power m30 b30
Hey
Im interested in getting a little more power out of my E34 530i M30B30. Where is the best place to start?.
Any advice would be great?
  kiwi6539 said:
Hey
Replace it with an M30B35
Cam change on mine was worth 20 hp, headers should be worth another 10 to 15.
I just had more duration ground into my existing cam, wasn't very costly at all, done by Franklin Cams in Pukekohe.
Ooops, mine is a B35, that would be the first change.
Edited by Silver Fox
The 3ltr is a sweet runner but you are better off following others advice & dropping in a 3.5ltr or just buy a 535is.(not really a 3.5, actual cc is 3430)
To give you some idea what gains are locked away in a 'good' M30b35 i gained approx 23hp@wheels running piggyback map system + headers.(supplied by wayney on bimmer)
23 wheel HP equates to approx 27 flywheel HP @ 15% drivetrain loss on a manual 5 speed.
Headers only gained approx 5HP@ wheels on stock engine but i'm sure with some internal engine work the headers would come into their own.
HP figures quoted are from a Dyno Dynamics dyno in shoot out mode, not fantasy dyno's that exist.
Edit, add in tuning thread if interested.
http://www.bimmersport.co.nz/forums/index....=16177&st=0
Edited by mr E34
depends whats your budget and what you are trying to get out of it .
remap or chip or a piggy back system will give 5-10 hp maybe
headers about 5hp
3.5 conversion 20-30hp depending on which engine year you choose.
realistically a 3.5 engine swap is the best bang for buck
engines go for anything from $500 to $1000 depeding on history and who you buy it from
costs about 1 to 2 days in labour costs .
or sell it and buy a 535is
all the above,or spend a little more for a completely satisfying result;
Cheers all for the advice.
Will have to sort budget and think what to do. M30b35 sounds like a go.
How much for that motor Bm weapon? I like it!
Stroke it and increase compression and change the cam
p'm me and i'll give you some options
