Dyl
Fuel tank issues
I have a problem that I have never had before.
My M Coupe will only fill to 3/4 of a tank. It will NOT fill any more. I have ruled out my gauge being faulty. It just won't take more than about $67 of 98 and then overflows if I put more in.
I have given the car a shake in case it hadn't filled any additional fuel cells in the tank but it hasn't worked.
Anyone??
I have no idea why, but your car looked hot as hell when i saw you take off at Newton Rd cnr of Ian McKinnon Dr traffic lights
Weird looking plastic thing isn't it? Only 50 lts to start with, are you sure it's not full? Maybe you should empty it completely and then fill it?
Guest Ari Gold
-----> http://www.bimmerfest.com/forums/showthrea...ight=fuel+gauge
http://www.mz3.net/articles/244.html
http://www.waycoolinc.com/z3/essentials/fixit/FSU/67212.html
Or try (at your own risk)
: Car off
: pull fuse 31
: car starts
: car off again
: replace fuse 31
: start car and check fuel gauge (no luck)
: car off
: pull fuse 23
: start car
: car off again
: replace fuse 23
: start car and check fuel gauge (yahoo - it works)
Cheers for the compliment mate! Make sure you toot your horn at me next time! The tank is a funny little plastic thing. Cheers for the links Sam. I'll do some investigating!
Fuse thing didn't work so back to the drawing board.... What is this techron stuff that they are talking about Sam?
