APT 201 Report post Posted March 19, 2010 Does anybody know if you can adjust the bonnet on a e30 ? The front end (headlights end) sits to low when closed,Ive tried putting washers to raise it up but then it doesnt want to clamp down and close, then ive tried adjusting the 3 mounting bolts on wither side but still no luck. Any other suggestions ? Thanks Andrew Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted March 19, 2010 have you had the gaurds on and off? they could be sitting too high. i have had the same issue and once i thought of the gaurds being too high rather than the bonnet too low i sorted it Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted March 19, 2010 take the grille out and adjust the bonnet catch, that should fix your problem. Quote Share this post Link to post Share on other sites
APT 201 Report post Posted March 19, 2010 What is the bonnet catch ? is it the lock on the drivers side? Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted March 19, 2010 It's on the passenger side, you have to take off the passenger side grill to get to it.. and it's got two bolts with the slidey grove... Quote Share this post Link to post Share on other sites
APT 201 Report post Posted March 20, 2010 it is already at its maximum. Will try the guards, are there a difference between FL and PFL and coupe and sedan ? The ones on the car dont have any side indicators Quote Share this post Link to post Share on other sites
Gotheschu 1 Report post Posted November 27, 2010 Hey Andy, Any luck with this. Mines the same at the moment.. Quote Share this post Link to post Share on other sites
