Katalyst 0 Report post Posted March 20, 2010 Hi all, have just put my engine back together after a few months of cleaning it all up, now it wont start!!!! not even a click from the starter!!! the only thing i wasnt 100% sure off was a small wire tht came from the end of the injector plug loom, a long wire with spade terminal and rubber boot - where is tht meant to go?? could there something else tht could be causing it that ive negleted to have done?? only took the induction system/intake manifold and rocker cover off really cheers Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted March 20, 2010 Battery charged? Spade terminal goes to one of the sensors on the thermostat housing. Quote Share this post Link to post Share on other sites
Katalyst 0 Report post Posted March 21, 2010 yeah battery is charged thermostat housing you say!!! hmmmmmmmmmmm Quote Share this post Link to post Share on other sites
Katalyst 0 Report post Posted March 21, 2010 are you sure?? there are the two sensors striaght after the injectors but i cant see no spade terminal?? the only one i can see is on the side of the distributor Quote Share this post Link to post Share on other sites
Driftit 2229 Report post Posted March 21, 2010 (edited) Long one with the spade is your Oil pressure switch wire (down under your oil filter) If it is not even turning over then you have connected your starter up wrong. On a PFL there should be two big wires (red and black) on one terminal. And two small wires on there own terminals. One below the main terminal and one next to it. If you have these backwards it will not turn over. Sometimes if you have them backwards the starter will not throw out and engage. Edited March 21, 2010 by driftit Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted March 21, 2010 Checked big earth strap from the sump? Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted March 21, 2010 What he said ^ Quote Share this post Link to post Share on other sites
