Eddie 66 Report post Posted March 21, 2010 has anyone here had anything to do with megasquirt? Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted March 21, 2010 Yep I've used Megasquirt 1 V3 with an m20 turbo before. Quote Share this post Link to post Share on other sites
barf 0 Report post Posted March 21, 2010 2 / 2 successful installs here, in e30s with m20b23 and m50b25. using MS2 with v3 PCB from diyautotune.com MS2Extra firmware Quote Share this post Link to post Share on other sites
nastnas 9 Report post Posted March 22, 2010 yup me aswell, on a 16V with ITBS! Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted March 22, 2010 yup me aswell, on a 16V with ITBS! what is needed for M44? Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted March 22, 2010 I used it as a fuel only setup on an M10 turbo. MS itself proved pretty reliable after a few teething issues Quote Share this post Link to post Share on other sites
rds 0 Report post Posted March 23, 2010 has anyone here had anything to do with megasquirt? Yea Barf and I have a M50B25 running with a MS at the moment. Complete new loom etc. Wideband sensor in the tailpipe, it goes mint. Without 1 minute of "professional help" Personally I think the system itself is awrsme, as long as your willing to learn a thing or 20 Quote Share this post Link to post Share on other sites
crshbndct 0 Report post Posted May 12, 2010 i just put a ms2 v3.57 onto a starion. was easy to set up, tune, and when we booked it into the dyno to get a final checkup tune, the guy said it didnt really need any tuning. had 2 knock sensors, wideband, and egt sensors. which helped a lot. Quote Share this post Link to post Share on other sites
mops 4 Report post Posted September 25, 2013 I have been daily driving a MS2 managed m20 turbo stroker for several years now. Once i got all the wiring and setup right, its working well. These days I would recommend MS3, this is however more expensve, but you get sequential fuel/spark, which you want. Sequential will not make more peak power, but it will be better in terms of drivability and fuel economy (slightly) Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted September 26, 2013 How is the freeems stuff going? Quote Share this post Link to post Share on other sites
mops 4 Report post Posted September 26, 2013 How is the freeems stuff going? Fred is UE now, and he's working on it. Bunch of cars running it. I guess check out the website ? I would say freeems is for people who are confortable with electronics - I would say its very DIY. Thing is, you can go and buy off-the-shelf product, installed and tuned. It will cost you $$$$. If budget is not an issue then this is definitely easier solution. MS and freeems are much cheaper solutions, but you will have to spend time to learn and do it right. And if you cut corners it might cost you more hassles. For me learing/installing EMS was an exciting adventure, and the knowledge I gained is usefull even when working with non-custom cars. Quote Share this post Link to post Share on other sites
nipe 1 Report post Posted September 26, 2013 Fred is UE now, and he's working on it. Bunch of cars running it. I guess check out the website ? I would say freeems is for people who are confortable with electronics - I would say its very DIY. Thing is, you can go and buy off-the-shelf product, installed and tuned. It will cost you $$$$. If budget is not an issue then this is definitely easier solution. MS and freeems are much cheaper solutions, but you will have to spend time to learn and do it right. And if you cut corners it might cost you more hassles. For me learing/installing EMS was an exciting adventure, and the knowledge I gained is usefull even when working with non-custom cars. Did you tune your MS yourself? Mine has been working fine once i set it up properly, but its only on base tune at the moment Quote Share this post Link to post Share on other sites
mops 4 Report post Posted September 26, 2013 Did you tune your MS yourself? Mine has been working fine once i set it up properly, but its only on base tune at the moment Sure. I have a wideband and I tune by hand on the road. Quote Share this post Link to post Share on other sites
nipe 1 Report post Posted September 27, 2013 Sure. I have a wideband and I tune by hand on the road. Nice, I need to have a chat to you for some useful tips as our setups are very very similar and I only did a little bit of tuning, got wideband and egt too Quote Share this post Link to post Share on other sites
