APT 198 Report post Posted April 1, 2010 Okay so recenetly i have noticed that my water temp gauge is going all over the show, ie showing its overheating when its fine then i tap it then it goes down to halfway, then it goes to cold. i have checked the grounding of the cluster and its the same deal. Then i have noticed my Speedometer needle starting to 'float' from 80 to 140 at times whilst im just cruising at 80. My question is does anybody know if an aftermarket components such as a Apexi RSM or similar can be easily wired up to my car, as i still want to have the factory gauges but also know what speed and tempereatures my car is on. If anyone could point me in the right direction it would be good. Thanks guys Andrew Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted April 1, 2010 try replacing your SI batteries Quote Share this post Link to post Share on other sites
