bellicose 9 Report post Posted April 9, 2010 I'm looking for a 3.5 M30 short block. Don't need head or any ancilaries, just block-crank-rods-pistons. Must also be an early block. IE: E12/E23/early E24/early E32. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted April 9, 2010 are you wanting the eraly early block with the flat pistons and 94mm bore with 84mm stroke with 10:1cr . or the little bit later one from e28 e23 e24 with 92mm bore and 86mm stroke with piano top pistons?? 10:1cr probably can help cheers brent Quote Share this post Link to post Share on other sites
bellicose 9 Report post Posted April 9, 2010 To be honest Brent, i don't know lol. I just know it needs to be an early block to suit the mounts in the E3, later blocks don't line up. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted April 9, 2010 The earlier blocks have the engine mounts further back, as opposed to the E34 etc which have their mounts closer to the front of the block. Quote Share this post Link to post Share on other sites
bellicose 9 Report post Posted April 9, 2010 The earlier blocks have the engine mounts further back, as opposed to the E34 etc which have their mounts closer to the front of the block. Thanks David, i knew 'bout the E34 blocks, but any idea what was the latest they used the early blocks? E28 E32? Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted April 9, 2010 E28 for sure John, and if I'm right, E32 before 88, Marty or Brent should know. Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted April 9, 2010 E28 for sure John, and if I'm right, E32 before 88, Marty or Brent should know. correct Dave,e23,e28 and early e32's. have a couple of blocks about the place. PM me for the exact bits your after. cheers marty Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted April 9, 2010 correct Dave,e23,e28 and early e32's. have a couple of blocks about the place. PM me for the exact bits your after. cheers marty also e24 blocks . most likly best option is the 1982(9 mth) to about 1987(9mth) block with the 10;1 pistons. and you can run them on the later motronic system if you like from a e34 535i and e32 735i etc Quote Share this post Link to post Share on other sites
HELLBM 1673 Report post Posted April 9, 2010 can do an`87 3.5 from a 735 Quote Share this post Link to post Share on other sites
