Brendan 0 Report post Posted April 16, 2010 Hi Some time ago I posted this topic but didnt get anywhere so I'm trying again.I'm doing a restore of this car which I've had for awhile and now want to replace the original carpet sets . There are two bonded sound insulation foam/ carpet parts which are split under the front seats. The foam is moulded to the floor pan shape so trying to just recarpet is problematic and I would prefer to find the correct parts .Jerry C's had them in stock Nov last year but BMW ended them in Dec and I understand the parts world wide have been returned to BMW. Probably to be auctioned off for RH drives to UK rest to where ever. Anybody able to help with leads on where I can try to source these two parts Part numbers 51471976660, 51471947323 Thanks Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted April 16, 2010 I would say your best bet is to source some mint second hand carpets, both E30’s I have had have had absolutely mint carpets so im guessing there would be plenty out there, sedan and touring will be the same. Call Ray at Hell BMW. If you want new an auto trimmer can re-trim the stock foam underlay with new carpet. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted April 16, 2010 I can get them X Germany 51471976660 $1102.01 +Gst 51471947323 $740.34 + Gst Quote Share this post Link to post Share on other sites
Guest Ari Gold Report post Posted April 16, 2010 I can get them X Germany 51471976660 $1102.01 +Gst 51471947323 $740.34 + Gst You couldn't possibly source actual black E30 carpet could you Glenn? Not the grey stuff, actual anthrazite. Can you run these numbers to see if I'm on the right track? 51 47 1 933 602 51 47 1 922 542 51 47 1 911 371 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted April 16, 2010 (edited) You couldn't possibly source actual black E30 carpet could you Glenn? Not the grey stuff, actual anthrazite. Can you run these numbers to see if I'm on the right track? 51 47 1 933 602 51 47 1 922 542 51 47 1 911 371 51 47 1 933 602 Getting a price on this. Might not be till Monday though...remind me 51 47 1 922 542 $223.78 + Gst 51 47 1 911 371 supercedes to 51 47 1 976 620 $287.25 + Gst All X Germany Edited April 16, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted April 16, 2010 (edited) 51 47 1 933 602 No longer available 51 47 1 922 542 $223.78 + Gst 51 47 1 911 371 supercedes to 51 47 1 976 620 $287.25 + Gst All X Germany Bugger Edited April 16, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
Guest Ari Gold Report post Posted April 16, 2010 bugger indeed! Is that Germany showing NLA? I've got 51471933411 showing $861.59USD, is it the same part? I'm guessing if it's telling you it's NLA, then it's very definitely NLA. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted April 16, 2010 (edited) bugger indeed! Is that Germany showing NLA? I've got 51471933411 showing $861.59USD, is it the same part? I'm guessing if it's telling you it's NLA, then it's very definitely NLA. 51471933411 is available X Germany @ $1102.00 + Gst If thats the front one...the heel pad will be on the wrong side Edited April 16, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
Brendan 0 Report post Posted April 16, 2010 I can get them X Germany 51471976660 $1102.01 +Gst 51471947323 $740.34 + Gst Hi Glenn Give me a call 360 2817 021 669000 Brendan Quote Share this post Link to post Share on other sites
Brendan 0 Report post Posted April 16, 2010 I would say your best bet is to source some mint second hand carpets, both E30’s I have had have had absolutely mint carpets so im guessing there would be plenty out there, sedan and touring will be the same. Call Ray at Hell BMW. If you want new an auto trimmer can re-trim the stock foam underlay with new carpet. Hi mate Thanks no the touring and sedan area different hence da problemo I'll see what Glenn says Thanks again Quote Share this post Link to post Share on other sites
Brendan 0 Report post Posted April 20, 2010 Hi Glenn Give me a call 360 2817 021 669000 Brendan Glenn Thanks for trying and you have had the same response I've had from BMW. I will take your advice and see if I can find some swedish sites which may turn up something thanks again Quote Share this post Link to post Share on other sites
