kiwi328i 118 Report post Posted April 18, 2010 Hi guys, I knew I should have bought it off trademe a while ago, but has anyone got a decent secondhand one of these hanging around? You know the part below the license plate, great whopping hole that usually has either mesh or slats. PM me if you need to otherwise all comments welcome. It should look like this one. Cheers Lionel Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted April 18, 2010 (edited) have half of that type in your pic , and a mesh one with some damage if thats any use to you . 021433600 Edited April 18, 2010 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
bmpower 3 Report post Posted April 18, 2010 Hi guys, I knew I should have bought it off trademe a while ago, but has anyone got a decent secondhand one of these hanging around? You know the part below the license plate, great whopping hole that usually has either mesh or slats. PM me if you need to otherwise all comments welcome. It should look like this one. Cheers Lionel Take the front bumper off, remove that 'grided' section from there and buy some mesh from supercheap - looks just as good if not better. Below is a pic of mine which i did using this method. I also meshed the fog lights too to be different! Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted April 18, 2010 Take the front bumper off, remove that 'grided' section from there and buy some mesh from supercheap - looks just as good if not better. Below is a pic of mine which i did using this method. I also meshed the fog lights too to be different! You're right that does look good, how did you mount the mesh? Quote Share this post Link to post Share on other sites
bmpower 3 Report post Posted April 18, 2010 You're right that does look good, how did you mount the mesh? I mounted the mesh exactly the same way the standard insert mounts. There are little 'nipples' that stick out on the inside of the bumper and small clips which go over them to lock it into place. It sounds more difficult than it is!! Once the bumper is removed you'll see exactly how it works! Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted April 18, 2010 Take the front bumper off, remove that 'grided' section from there and buy some mesh from supercheap - looks just as good if not better. Below is a pic of mine which i did using this method. I also meshed the fog lights too to be different! Did you buy another set of wheels Quote Share this post Link to post Share on other sites
bmpower 3 Report post Posted April 19, 2010 Did you buy another set of wheels Haha nah don't have these anymore - bought off trademe a while back, but when i had them put on the car and spun up on the balance machine we found they were f**ked! Buckles and flat spots! So i gave them back to the previous owner... Lesson learnt... They did look quite cool though! Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted April 19, 2010 also i can order in new grill and bumper trim inserts as a kit about $120 Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted April 19, 2010 also i can order in new grill and bumper trim inserts as a kit about $120 The middle trim bit with the "BMW stamp" included? Quote Share this post Link to post Share on other sites
kiwi328i 118 Report post Posted April 19, 2010 also i can order in new grill and bumper trim inserts as a kit about $120 I am trying to do everything secondhand for now, cause I like to restore or reuse old stuff anyhow but sh*t that is cheap, if I dont have any joy I will let you know for sure. Is the grill you speak of, the grill that I am after the slat type? and the inserts are the 4 smallish black textured moulded plastic bodymould strips? Thats cheap. I am working on mine at the mo, I have it down at the plastic repairers, bought a secondhand m-sport bumper and it needs a sh*t load of work. The strips are covered in layers of paint, but I might be able to strip them without killing the textured pattern...I hope. The bumper has no braking vents or those nifty rivets to attach it to the 'bar' either, so can you help there? oh yeah it doesnt have one of the side attachments that are factory glued on I think the right hand side, can I use my old one or is it m-sport bumper specific. Here is an image of the side bracket. Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted April 19, 2010 same as in my pic . no bmw logo in the centre . but i might have a spare one of those at work ?? Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted April 20, 2010 If you have a BMW logo one, I'll take it hands down. Quote Share this post Link to post Share on other sites
