hihaterz 0 Report post Posted April 20, 2010 Hi Guys the OBC shows check coolant level?? ideas?? how to check etc?? Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted April 20, 2010 Hi Guys the OBC shows check coolant level?? ideas?? how to check etc?? Its a sensor usually in the radiator expansion bottle.. Will light up when coolant level is low. Is there any coolant in there?? Quote Share this post Link to post Share on other sites
tire 10 Report post Posted April 20, 2010 Make sure the plug in the expansion tank is in properly. Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted April 20, 2010 And also note that this can go off under hard cornering/braking.... As any of us running an OBC found out at the last Intermarque Sprints Quote Share this post Link to post Share on other sites
hihaterz 0 Report post Posted April 20, 2010 Make sure the plug in the expansion tank is in properly. Thanks for the quick repsonses guys I will have a look after work. Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted April 20, 2010 Just remember to check this when cold, Its pressurized, don't want you to go burning yourself. Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted April 20, 2010 The sensor will be at the bottom of the expansion tank. So you might want to place a pail there when you have it out. To be honest I wouldn't take it out just yet. Sometimes it's the contacts on the sensor which attach to the wire - take that off and give the contacts a light sand, has worked for me. Quote Share this post Link to post Share on other sites
