bimmer boy 21 Report post Posted February 19, 2005 was looking through my last WOF inspection sheet and thought id start doing a few things on my car to get it going so if i sell it the buyer will hav a working car or if i keep it i know it will work so i was wondering how one would go about 'remedy play in rack'??? and got a few other things like a worn steering universal and link rod end loose (sway bar i think) so are these easy to do like i can do myself? thanks in advance cheers Quote Share this post Link to post Share on other sites
petone 0 Report post Posted February 19, 2005 I think that those things he mentioned are causing the play in the rack, I've never heard of a rack wearing out. The link rod end could also possible be the tie-rod end, which shouldn't be too hard to replace. you will need an alignment afterward though. if it is sway bar related then thats also a pretty easy job. Quote Share this post Link to post Share on other sites
CaM 0 Report post Posted February 20, 2005 could be meaning inner tie rod end or something like that, racks do wear.... Quote Share this post Link to post Share on other sites
bimmer boy 21 Report post Posted February 20, 2005 ok this is exactly what it say in the sheet ' right front sway bar link rod loose' 'remedy play right side of rack' ' lower steering universal worn' Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted February 20, 2005 i have the parts from a 1986 320iA done 198000km Quote Share this post Link to post Share on other sites
bimmer boy 21 Report post Posted February 20, 2005 hmm thats exactly the same as mine but the k's on ur 320 is a bit less than mine so do u know if it starts up fine? mine has a occasional embarassing grind of the dizzy cap form time to time yea so when i know for sure wat im gunna do im gunnna get the parts from you could proberbly pick up the dizzy cap and rotor off you sometime soon Quote Share this post Link to post Share on other sites
