dreadful1 7 Report post Posted May 17, 2010 hey, I came across a little problem when Nick noticed that I was reversing but my reversing lights weren't on so I thought it was the bulbs so just then I went to repco and just bought myself a pair of the bulbs but when I put them on, they never turned on when I put shift the car to reverse gear.. Anyone got any ideas on this? Cheers, Yongxi Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted May 17, 2010 My guess would be either the switch needs to be replaced. here is a DIY for it http://www.unitedbimmer.com/forums/bmw-oem...switch-diy.html or there is a short. Most likely between the boot and boot lid Quote Share this post Link to post Share on other sites
dreadful1 7 Report post Posted May 17, 2010 My guess would be either the switch needs to be replaced. here is a DIY for it http://www.unitedbimmer.com/forums/bmw-oem...switch-diy.html or there is a short. Most likely between the boot and boot lid Wow cheers for the quick reply, I may think this might be the problem. If there is a short between the boot and the bootlid wouldn't all the rear lights not work? Quote Share this post Link to post Share on other sites
Docile 64 Report post Posted May 17, 2010 atm i have the same sorta problem. but mine is with the brake lights. all 3. found out that the problem is the brake light switch on the brake pedal. check your fuse box first. find the fuse that corresponds to the rear reverse lights. then next would probably be the reverse light switch. Quote Share this post Link to post Share on other sites
dreadful1 7 Report post Posted May 18, 2010 Cheers for the feedback guys, Got it sorted and fixed at Glenn's workshop, better leave it to the pros haha! Quote Share this post Link to post Share on other sites
