dirtydoogle 383 Report post Posted May 20, 2010 My 94 E36 has the build code with MSport body and suspension, but, I still "need" to clarify. To my understanding the car will be a wee bit lower with higher damping rates, stiffer springs and fatter sway bars. Am I correct? I am not able to find a way of identifying the struts or springs between standard or MSport, so I measured the hieght between the ground and the front sill [at the rear of front wheel arch] and got 131mm. I measured the dirt covered front sway bar as 25.83mm, which seems too small to me. It sits nice and fairly flat, has brilliant bump controll [near perfect really] and compared to my brothers old E36 325 sedan of the same year, rides very hard and flat. Any proper info would be great thanks guys! Oh, the rear sway bar is about as thick as a gnats nudger..... Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted May 20, 2010 http://www.bimmersport.co.nz/forums/index....p;hl=motorsport Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted May 20, 2010 Doesn't give me the sizes for the sway bars. Helpful though. I forgot about that link Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted May 20, 2010 front http://www.realoem.com/bmw/showparts.do?mo...hg=31&fg=10 rear http://www.realoem.com/bmw/showparts.do?mo...hg=33&fg=45 Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted May 20, 2010 (edited) Excellent work thanks mate! I have MSport sway bars than, the rear is 18mm. I'm quite happy now =D Edited May 20, 2010 by Duckeater Quote Share this post Link to post Share on other sites
