bmw335i 16 Report post Posted June 1, 2010 Hi guys just wanting to sort out afew little probs with my e34. 1 when i flick up the window wiper lever up once, it works fine. up another click it stays the same as click one. then on setting 3 it goes hardout like it should. So does anyone know why setting 2 isnt working as it should ? 2 sometimes when im driving along, need to slow down so i put the clutch in and the revs drop to or below 500rpm then it shoots up to 1500rmp and holds for a second or two, could this be the afm or o2 sensor? any help would be great thanks troy. Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted June 1, 2010 e34 , e32 , e36 onwards . all have teh same feature , when you pull upto a stop or going real slow the wipers go from number 1 speed to intermitant then as you drive off they go back to number 1 speed. as to the other fault , check for vac leaks ,air hoses split etc and or clean /lube or replace the icv (idle control valve) . also could be worn afm etc . but check the simple things first . Quote Share this post Link to post Share on other sites
bmw335i 16 Report post Posted June 1, 2010 thanks brent. but no matter how fast im going the wipers have the same problem. i know what u mean by they slow down when u go slower than say 5k's parents bmws do it. cheers Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted June 1, 2010 faulty wiper motor or wiper control box Quote Share this post Link to post Share on other sites
