tire 10 Report post Posted June 2, 2010 Hey if I get an alignment now then fit spacers to the rear will they throw out my alignment? Also, if my wheels aren't hubcentric does that mean they can't be aligned? Cheers. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 2, 2010 Spacers on the rear of your car is going to increase the rubbing problem you already have. It will make it worse without some serious guard rolling Max Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted June 3, 2010 It wont throw out your alignment. Not being hubcentric also wont effect your alignment. BUT it is illegal.. My front wheels arent hubcentric to the hub, and aside from the legal issues the only thing I face is getting the wheel on right. Its a matter of doing up the nuts evenly and torquing them all the same. Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted June 3, 2010 My front wheels arent hubcentric to the hub, and aside from the legal issues the only thing I face is getting the wheel on right. Its a matter of doing up the nuts evenly and torquing them all the same. Wow! How do you get on with that? If I run E39 rims on the front without hubcentric rings I know all about it! Can't you get some rings machined up to save any hassles? Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted June 3, 2010 ^ that would be the best plan Quote Share this post Link to post Share on other sites
tire 10 Report post Posted June 3, 2010 (edited) Spacers on the rear of your car is going to increase the rubbing problem you already have. It will make it worse without some serious guard rolling Max It wont throw out your alignment. Not being hubcentric also wont effect your alignment. BUT it is illegal.. My front wheels arent hubcentric to the hub, and aside from the legal issues the only thing I face is getting the wheel on right. Its a matter of doing up the nuts evenly and torquing them all the same. really? I get the wobs from like 90kph onwards. Il have another go mounting them then thanks for the tip. Yea I know about the illegality, I've got wof wheels Wow! How do you get on with that? If I run E39 rims on the front without hubcentric rings I know all about it! Can't you get some rings machined up to save any hassles? Jono is looking at hubcentrifying my shiz now. I can't get rings machined up becauase apparently they will be too thin which makes them too brittle. Edited June 3, 2010 by tastic Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted June 3, 2010 Wow! How do you get on with that?Only get wobbles at around 130.. Ive run non-hubcentric for the 2 years or so that Ive owned that wagon and never had any WOF issues or mechanical issues Quote Share this post Link to post Share on other sites
Eagle 1773 Report post Posted June 3, 2010 Just as well you dont goto track days lol Quote Share this post Link to post Share on other sites
zenetti 0 Report post Posted June 3, 2010 (edited) Jono is looking at hubcentrifying my shiz now. I can't get rings machined up becauase apparently they will be too thin which makes them birttle. I thinkthe best way for us to try and solve this is to attach the spacer to the back of the wheel and put a hubcentric ring in the spacer. Bring all your shizz in and we will have a look at it for you. We may need the wheels for a few days, and it goes withut saying .. you wil need a cert. Edited June 3, 2010 by zenetti Quote Share this post Link to post Share on other sites
tire 10 Report post Posted June 7, 2010 So turns out my front wheels were 80gm out of balance and I was running a total of -1.84 front toe. So I got that sorted then mounted the wheels as squere as possible with even torque on the bolts and bam, no wobs up to at least 120! Stoked! Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted June 7, 2010 my race rims arnt hubcentric.... dont have any issues with them... just make sure they are nice and tight, they dont wobble or anything. Quote Share this post Link to post Share on other sites
