tire 10 Report post Posted June 3, 2010 (edited) It's time to put these up for sale properly. Front and back coilovers to suit an E30, made by Ground Control USA (springs are Eibach). No shocks. They are new. Never been used. I paid a little over $600nzd for these when I was on oz, so I'm looking for realistic offers around that mark. Thanks, Max 027 354 5576. Edited June 5, 2010 by tastic Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted June 3, 2010 your timing is disasterous Quote Share this post Link to post Share on other sites
tire 10 Report post Posted June 3, 2010 (edited) Ha whys that? Want to work something out? Just call me. Edited June 3, 2010 by tastic Quote Share this post Link to post Share on other sites
beemwr 47 Report post Posted June 4, 2010 yeah, could be put to good use. PM'd Quote Share this post Link to post Share on other sites
sascha 17 Report post Posted June 4, 2010 Can these be used with any e30 shocks? i dont know much about them but seem a good cheaper alternative to expensive coil overs. How much work is involved installing them? do the height adjusters get mounted on the shock? Cheers Quote Share this post Link to post Share on other sites
tire 10 Report post Posted June 4, 2010 Can these be used with any e30 shocks? i dont know much about them but seem a good cheaper alternative to expensive coil overs. How much work is involved installing them? do the height adjusters get mounted on the shock? Cheers These are the "expensive" coilovers, all the serious people use GC I believe there is some welding involved to fit them to the front, and I think you can use any shock but I'm not 100% sure - can anyone else (Henry) chip in? Quote Share this post Link to post Share on other sites
APT 205 Report post Posted June 4, 2010 To use these you must get the front perches welded in. PM Ashkan for a contact i think its around $300 . The rears will go in as per normal. Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted June 4, 2010 (edited) And you will need the correct length shocks if you want them to be captive, suitably short bodied shocks if you want to lower it materially and be captive (short body, not just shorter travel on the normal size shocks) and this is when you have to cut and shorten the strut, and some reasonably brain taxing calculations if you want to do the above. Edited June 4, 2010 by CamB Quote Share this post Link to post Share on other sites
sascha 17 Report post Posted June 4, 2010 Oh yeah i know that GC coil overs are the expensive ones, but thought that these were different to the full ones that cost a few thousand? Or are these just the same, only they dont have shocks yet? I thought these were somehow a cheaper version of Ground Controls.. sorry, my bad! Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted June 4, 2010 They are. The full set is abit different, these just look to be the springs and adjustable perches? The full set includes short housing adjustable shocks and adjustable top hats. Quote Share this post Link to post Share on other sites
tire 10 Report post Posted June 5, 2010 Sellage. Quote Share this post Link to post Share on other sites
