mattgoldsbro 0 Report post Posted June 8, 2010 Hi all was just wanting to see if it was possible to fit a later model Auto shift knob to replace the T bar style one in my 96 E36 ? Thought it might modernise the appearance etc Cheers Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted June 8, 2010 Yes, it can be done. But you need to replace the whole shifter and not just the knob as there are a few small differences between the shifter arm and mechanism on early and late cars. There are writeups on the net, a search on Google should help you out. Quote Share this post Link to post Share on other sites
mattgoldsbro 0 Report post Posted June 8, 2010 Yes, it can be done. But you need to replace the whole shifter and not just the knob as there are a few small differences between the shifter arm and mechanism on early and late cars. There are writeups on the net, a search on Google should help you out. Cool thanks ! will check it out Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted June 8, 2010 correct , you will need the shifter mech as it has a different size shaft . can do if needed. its a nice upgrade Quote Share this post Link to post Share on other sites
mattgoldsbro 0 Report post Posted June 9, 2010 correct , you will need the shifter mech as it has a different size shaft . can do if needed. its a nice upgrade Can you please let me know of price, Not sure if it will be worth doing ? Thanks Quote Share this post Link to post Share on other sites
