Druid 0 Report post Posted June 20, 2010 Morning all. Our 1994 BMW 318iS sometimes revs for no apparent reason. Can be driving, or sitting in gear, or out of gear. It will sometimes rev up and down every second or so, sometimes just sit on the higher revs. Can be anywhere between about 1500 and 4000RPM when out of gear. There is a sensor towards front of engine, on passenger side, below the manifold. Moving that wire will often alleviate the problem, or make t happen. If it's in the rev mood, and then ignition is turned off, it won't fire up, just turns over, until that wire is moved. What is that sensor, (temperature sensor?) and would it be the actual sensor, or a wire damaged inside that part of loom, or the plug that fits onto the sensor? Or is it likely to be some other reason? If it's the wire, should I cut it back and solder in another wire in place of it? What's that sensor worth if it needs replacing? I have puulled the plug off, and pushed it on and off a number of times to be sure there isn't oxidisation stopping proper contact, but it looks okay. Many thanks. Keith Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted June 21, 2010 Hi Keith, where abouts are you? if you are in wellington give us a yell, will be happy to help. cheers J & K 04 3801089 Quote Share this post Link to post Share on other sites
Druid 0 Report post Posted June 21, 2010 Hi Keith, where abouts are you? if you are in wellington give us a yell, will be happy to help. cheers J & K 04 3801089 No, unfortunately, I'm in South Auckland, but thanks anyway. Quote Share this post Link to post Share on other sites
Druid 0 Report post Posted July 3, 2010 Some more information, plus a photo. If the plug is taken off the sensor, the car will start and idle fine. If it's cold, it will not take any throttle, but warmed up, the car will run great, no surging, or anything untoward. The photo shows the sensor in question, directly behind the oil filter, under the front of the intake manifold. I assume it's a temperature sensor, although not for the temperature gauge. Am I correct in that thought, and would it be the actual sensor which has a problem? Where's the best place to get a replacement? Thanks again. Quote Share this post Link to post Share on other sites
HELLBM 1674 Report post Posted July 3, 2010 Can sort it out for you. Call or text Quote Share this post Link to post Share on other sites
Guest BimmerzE36 Report post Posted July 4, 2010 (edited) Morning all. Our 1994 BMW 318iS sometimes revs for no apparent reason. Can be driving, or sitting in gear, or out of gear. It will sometimes rev up and down every second or so, sometimes just sit on the higher revs. The same thing happens to me actually, but its not that bad, only revs up and down between say 1K and 2K when its not in gear. Once its in gear its all fine. let me know when you get it sorted mate, Can sort it out for you. Call or text If it gets worst, I'll know who to call up. Cheers Edited July 4, 2010 by BimmerzE36 Quote Share this post Link to post Share on other sites
Druid 0 Report post Posted July 10, 2010 The same thing happens to me actually, but its not that bad, only revs up and down between say 1K and 2K when its not in gear. Once its in gear its all fine. let me know when you get it sorted mate, If it gets worst, I'll know who to call up. Cheers Well, so far, so good. Have only done 10km out, then after 2 hours, the same 10k back, but with no problems. Need a bit more travel time to confirm it, but it's looking good, so far. Hoping it will also bring fuel consumption back to where it used to be Cheers. Quote Share this post Link to post Share on other sites
3 SERIES 93 Report post Posted July 10, 2010 Well, so far, so good. Have only done 10km out, then after 2 hours, the same 10k back, but with no problems. Need a bit more travel time to confirm it, but it's looking good, so far. Hoping it will also bring fuel consumption back to where it used to be Cheers. What did you end up doing to fix the problem? You havnt actually said... Quote Share this post Link to post Share on other sites
Druid 0 Report post Posted July 10, 2010 (edited) What did you end up doing to fix the problem? You havnt actually said... Ooops. Lol. I replaced the temperature sensor in the photo, with a second hand one supplied by HELLBM. Now I just need to do some more running to confirm it's all working properly. The car is not a daily driver at the moment, but will be again when University restarts. The car belongs to my son's girlfriend, and I'm teaching her to drive in it. Edited July 10, 2010 by Druid Quote Share this post Link to post Share on other sites
Druid 0 Report post Posted July 25, 2010 Well, it looks as if we're definitely in business. Done close to a couple hundred kms since replacement of the sensor, and all is well:) Just watching out for economy now, see if that's also improved. Thanks guys Quote Share this post Link to post Share on other sites
