bellicose 9 Report post Posted June 30, 2010 Ok so i was checking out an M30 powered car (secret squirrel lol) the other day and it was blowing white smoke, no it's not turboed but it was the same as when a turbo shits itself. The smoke smelt like very old stale petrol, the car starts and runs ok, sometimes drops a cylinder when idleing then comes right again. It doesn't run hot and water level ok, no signs of water in oil. While it's running at idle and you take the oil fill cap off rocker cover the idle rev's drop 'bout 100. The owner told me, as the trans' is a GM Borg Warner the modulator diaphram is holed or cracked and therefore sucking oil up into the manifold and then getting burnt...............! Now i've owned many, many GM cars with Borg Warner box's and never come across this before. Any ideas guys? cheeRS, John. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 30, 2010 (edited) Someones telling you porkies. No BMW's have vacuum modulators. Mercs do and its quite common. Edited June 30, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
bellicose 9 Report post Posted June 30, 2010 Thought it sounded odd Glenn. Any ideas on the smoke ? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 30, 2010 Smoke or steam ? Quote Share this post Link to post Share on other sites
bellicose 9 Report post Posted June 30, 2010 Smoke or steam ? Was pretty hard to tell, didn't really disapate (sp?) like steam does. Also, smoke / steam? started pooring out as soon as you started the car, it hadn't been started for 'bout a month before i got there. You could almost swear it had a blown turbo, looked exactly the same as a Mitzy Cordia i had when i blew the turbo. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 30, 2010 M30's are prone to cracking heads & blocks... which sometimes doesnt give a problem unless driven... with load the cracks open and do what this is doing. I had one once that we had to dyno to diagnose the problem. It went well too with the water injection. Quote Share this post Link to post Share on other sites
bellicose 9 Report post Posted June 30, 2010 Thanks Glenn, i just rang the guy and told him i'll give it a miss. Think i dodged a bullet there lol. Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted June 30, 2010 valve guides go hard and let oil down in the combustion shape. bmw m30's use zf autos or getrag manuals Quote Share this post Link to post Share on other sites
