_Matt_ 42 Report post Posted July 1, 2010 This is probably the most concerning problem i have at the moment. I found water under the carpet in the boot and also the foam right at the back under the carpet had soaked up quite a bit. I dried it up but today i opened up the boot to find condensation covering the whole underside of the boot lid. i thought water may have got in from somewhere but now condensation? I've never seen this before. any ideas? Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted July 1, 2010 A lot of E28s leak into the boot, and from there into the rear seat floor area. Normally the boot seal is the culprit, but sometimes even with a good seal, mainly when you have the car parked with the boot higher than the front. The condensation is just due to the weather at the moment, cold nights with moisture already in there and you'll get it every time. Quote Share this post Link to post Share on other sites
Wervie67 0 Report post Posted July 1, 2010 ive had a similar problem with mine, took a while to figure it out, but was really simple. may apply to you, may not culprit: The aerial from my radio was missing, so every time it rained, water seeped into the boot, and left a rather large puddle down the left side. nothing a bit of liquid nails couldn't fix though! Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted July 1, 2010 (edited) alrighty, cheers. I can confirm the seals look pretty top notch, rust near lids latch is all i see but the surface rust deep in the boot (near seats) concerns me a bit aye :/ e: my aerial is there (water is predominantly showing on the passengers side) aerial is on drivers side. Edited July 1, 2010 by _Matt_ Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 1, 2010 Remove everthing from the boot, get inside with a torch and get a mate to hose it down in the area you think it might be leaking... shouldn't be too hard to find where it's coming from Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted July 11, 2010 o.k, so i'm in deep now! so to speak. here is what i have found...looks like the seals around the left tail light have failed and no one cared to have a look why water was getting in their boot. i knocked over my beer to top things off Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted July 11, 2010 that's a real shame mate, other than that it is a nice looking E28 Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted July 11, 2010 that's a real shame mate, other than that it is a nice looking E28 as long as i can prevent any further damage i'm happy. the screw in the second pic is missing because the fitting thread on the light has been broken, maybe that let some in. there was water filling the side lens, so much so i only noticed it when some drained out and i could see the water level :/ i have cleaned it all up and siliconed the sh*t out of it so lets hope for the best. ill keep the boot linings off to keep an eye on it. missing screw: water filled lens: cleaned up (might cut the rust out when i can) Quote Share this post Link to post Share on other sites
