pommy 33 Report post Posted July 3, 2010 for some reason my electric windows dont work, I have checked the fuse also checked its the right fuse! I have changed the window switch just in case still no action has any one got any other ideas? thanks. Quote Share this post Link to post Share on other sites
Guest BimmerzE36 Report post Posted July 3, 2010 for some reason my electric windows dont work, I have checked the fuse also checked its the right fuse! I have changed the window switch just in case still no action has any one got any other ideas? thanks. This might not be the best solution or a solution at all, but have you tried removing the door interior panels, and check to see if there's any play in there, double check the wiring harness and all that ? It might just be something very simple. Its a very easy process if your patient, all you need is Size 20 / 25 Torex drivers I think.. Quote Share this post Link to post Share on other sites
M325is 0 Report post Posted July 3, 2010 (edited) Do you have a button up by your demister button that doesnt have any picture or words on it? Push this, its like a kill switch for your electrics, push it again they come back on. Edited July 3, 2010 by M325is Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted July 3, 2010 his car is facelift, so if its not there, it will be down on the center console by the gearstick Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted July 3, 2010 is it all windows or just one? sounds like you hit the kill switch. either that or there is a common power issue. do the switches light up when you open the door.? Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted July 3, 2010 thanks Guys , I will have a look tomorrow. no I have nt noticed that the switches light up when you open the doors! it is both wondows! I hope it is just as simple as the kill switch it gets quite hot when your driving around. Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted July 5, 2010 could also be a faulty switch have plenty in stock J&K JK Southern Euro 04 3801089 Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted July 5, 2010 thanks Guys have solved the problem ! the dead switch was stuck. Quote Share this post Link to post Share on other sites
