Guest Simon* Report post Posted July 7, 2010 "As seen on trademe" http://www.trademe.co.nz/a.aspx?id=301988997 Quote Share this post Link to post Share on other sites
antony 0 Report post Posted July 7, 2010 "As seen on bimmersport" here. and here. From a different seller tho, these are slightly cheaper, although I think most people are holding out for Johnno's as they should be cheaper again. Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted July 7, 2010 A Mod repost is a significantly worse offence that a noob repost. Ban? Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted July 7, 2010 A Mod repost is a significantly worse offence that a noob repost. Ban? Haha screw you I'll ban myself!!! With respect, I DID look. A thread by Mitch titled "good copy" is pretty pathetic so I take no blame there And I flat out just didn't see JiB's Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted July 7, 2010 Thirdly, .... Seller is a member And Johno's reps are straight out weaves - no bolts, real or fake as the case may be Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3013 Report post Posted July 7, 2010 Seller is a member Bimmersport discount ?? Quote Share this post Link to post Share on other sites
zenetti 0 Report post Posted July 7, 2010 (edited) Thirdly, .... And Johno's reps are straight out weaves - no bolts, real or fake as the case may be Check the pics Simon, ours have the fake bolts as well, but we have BBS centres. Ours are also a more aggressive offset - +15 Ours are finally on the water now - check the updated wheels section! Edited July 7, 2010 by zenetti Quote Share this post Link to post Share on other sites
