98_s14
E30 Front Lip + Few Other bits
Hi all,
I'm after a front lip for a facelift E30, the 318iS lip would be lovely, but I doubt anyway has one they'd part with....normal lip would do fine.
Also after:
- the pre-radiator shroud from a South African E30....ie the bit of plastic before the radiator. (it just needs to allow for the deeper radiator).
- brake proportioning valve from a disc rear E30
Any or all of these would be much appreciated, please PM or reply.
Thanks a lot :)
What is the brake proportioning valve? If you tell me/take a pic I can have a look at the parts E30 tomorrow and tell ya.
edit: Oh, and the shroud thing. Not entirely sure what bit that is?
Edited by Top Secret
I've found a front lip I think, just waiting to hear back from APT.
Part number 2 below is the bit I mean, the plastic bit that ducts air into the radiator.
Posted Image
The brake proportioning valve is part number 5 below, has to be from a car with rear disc brakes.
Posted Image
Thanks for your reply Top Secret, are those pictures big enough to see?
just to check, that piece you have shown is not compatable with aircon... do you have aircon in your car?
Appreciate the heads up thanks Andy, I don't have AC in the race car but it would be nice :D
I was more trying to demonstrate roughly which bit of plastic I meant. I bought a SA radiator because it was a bit deeper than the one I had, but the plastic duct I have now blocks the lower 1/3rd or so.
Get my PM Re. Front lip ?
Yeah I did, I will try to pick it up tomorrow after work. I'll text you tomorrow to see what suits,
Thanks again
Bump. Lip found, thanks Andrew.
Still after proportioning valve from disc rear E30...and radiator shroud from South African E30.
Cheers
