Shady
No Tag on Diff.
The Diff off the car I am stripping. But it has no Tag on it. Is there any other way to tell what ratio it is, or is just going to be forever 'unknown'... ?
Mark both sides of the input shaft on the front, and one of the output shafts on the side, then turn the front one full revolution and see how many times the side shaft rotates. It will be between 3.45 and 4.45 times I would guess.
Other way round Dave. Turn the axles one revolution and count the number of turns the input shaft (pinion) turns.
3.45 :1 = I turn of the axles (output) / 3.45 turns of the input (pinion shaft)
A bit early I think ? :P
OK, a bit confusing but I'll figure it out... a bit wet to do anything yet, will do when it dries up (if it does). Thanks guys.
