325_driver 422 Report post Posted August 14, 2010 Right, so the engine came out, to replace a rocker rail. and on the way in / out, the lead that goes from the coil -> dizzy got snapped, we found another one that had the same fittings from a Golf VW, but cant seem to get it to fire timing is fine, e.g. nothing has been changed. Can you mix and match HT / leads, or is this not recommended, as some leads may have a max voltage they can handle, thus not providing enough spark to the plugs ? (replacing it when the week finally comes, just want some heads up) Any advice / knowledge on this Greatly appreciated Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted August 15, 2010 (edited) Have replaced main lead from coil to dizzy. I have spark, I have fuel I have Air, Timing is fine (the timing light is flashing on the line between the 0 | T on the crank pulley, correct me if it should be some thing else) Still not starting, any reason why this could be ?? Help ## edit, Clearances are to spec, and i have compression (170 - 180psi) ! Edited August 15, 2010 by 325_driver Quote Share this post Link to post Share on other sites
polley 916 Report post Posted August 15, 2010 Where did you check for spark? Did you pull out a plug and check or just at the lead? Your plugs may be stuffed. Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted August 15, 2010 Where did you check for spark? Did you pull out a plug and check or just at the lead? Your plugs may be stuffed. lead is sparking, plug is sparking, this is just down right weird Quote Share this post Link to post Share on other sites
polley 916 Report post Posted August 15, 2010 (edited) Are the plugs wet when you pull them out? ie. are the injectors firing? If not, test for power at the injectors, and signal. (signal is a pulsed earth from ecu) Edited August 15, 2010 by polley Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted August 15, 2010 Turns out, some one had done a botch up job on some sort of a fuel pump kill switch, and the fuel had decided to stop pumping after i checked it ! as i started checking every thing again ! This is turning into a nightmare Quote Share this post Link to post Share on other sites
