325_driver
Engine in .... again, this time its interesting
Right, so the engine came out, to replace a rocker rail.
and on the way in / out, the lead that goes from the coil -> dizzy got snapped,
we found another one that had the same fittings from a Golf VW, but cant seem to get it to fire
timing is fine, e.g. nothing has been changed.
Can you mix and match HT / leads, or is this not recommended, as some leads may have a max voltage they can handle, thus not providing enough spark to the plugs ? (replacing it when the week finally comes, just want some heads up)
Any advice / knowledge on this
Greatly appreciated
Have replaced main lead from coil to dizzy.
I have spark,
I have fuel
I have Air,
Timing is fine (the timing light is flashing on the line between the 0 | T on the crank pulley, correct me if it should be some thing else)
Still not starting, any reason why this could be ??
Help
## edit,
Clearances are to spec,
and i have compression (170 - 180psi) !
Edited by 325_driver
Where did you check for spark? Did you pull out a plug and check or just at the lead? Your plugs may be stuffed.
lead is sparking, plug is sparking, this is just down right weird
Are the plugs wet when you pull them out? ie. are the injectors firing?
If not, test for power at the injectors, and signal. (signal is a pulsed earth from ecu)
Edited by polley
Turns out, some one had done a botch up job on some sort of a fuel pump kill switch, and the fuel had decided to stop pumping after i checked it ! as i started checking every thing again !
This is turning into a nightmare
