myniu 0 Report post Posted August 23, 2010 Hi hi Having some problem again....early of the month I did a service at AA.... A few days later I noticed that at times my air conditioning is not running...... Couldn't figure out what went wrong....either some parts need to be replaced or some thing needs to be set? Tried to search the old articles but did not find anything that helps... Wondering if someone can give me some clue what might be wrong? Cheers Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted August 23, 2010 do the lights go out or does the fan stop or is the a/c just not working . could be the fan resistor ?? Quote Share this post Link to post Share on other sites
HELLBM 1696 Report post Posted August 23, 2010 Hi hi Having some problem again....early of the month I did a service at AA.... A few days later I noticed that at times my air conditioning is not running...... Couldn't figure out what went wrong....either some parts need to be replaced or some thing needs to be set? Tried to search the old articles but did not find anything that helps... Wondering if someone can give me some clue what might be wrong? Cheers Call around and I`ll run a diagnostic for you. We`re in Silverdale with all parts required for a solution.regards Ray Quote Share this post Link to post Share on other sites
myniu 0 Report post Posted August 24, 2010 everything worked as normal light comes up all buttons working great just at times there was no airflow coming out might be the resistor(?) would be a good idea to run a diagnostic but need to find a time first.... Ray would you mind PM me the address? Quote Share this post Link to post Share on other sites
