skuter 0 Report post Posted August 27, 2010 Hi I have bit of a problem with washer fluid, basically when I try to wash the windscreen, a little water goes and then it just stops i filled the washer fluid tank to the top but no spray action is happening at windscreen. Now I did check that jets are not disconnected doesnt seem to be case. so my question is could it be the pump or something else? how do you check that pump is working? any help appreciated. Quote Share this post Link to post Share on other sites
JFry 1 Report post Posted August 27, 2010 Easiest way is if it's making a noise. You could also check the piping for leaks etc. If you're getting a little bit of water each time i'd say it's losing pressure somewhere. Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted August 27, 2010 Pumps are a common problem... they also leak from the shaft seal & drain the resevoir Quote Share this post Link to post Share on other sites
skuter 0 Report post Posted August 27, 2010 Easiest way is if it's making a noise. You could also check the piping for leaks etc. If you're getting a little bit of water each time i'd say it's losing pressure somewhere. thanks i will check it out on the weekend see if the pump is making any noise. Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted August 27, 2010 thanks i will check it out on the weekend see if the pump is making any noise. It can also make a noise without pumping... so don't be fooled by noise Quote Share this post Link to post Share on other sites
skuter 0 Report post Posted August 27, 2010 It can also make a noise without pumping... so don't be fooled by noise thanks for the tip will check the pump and see maybe if the "blockage" is somwhere else as well. the washer tank is full from front so i doubt there is a leak, cant notice any wet paches but will check it all and see thanks for help Quote Share this post Link to post Share on other sites
skuter 0 Report post Posted September 4, 2010 thanks for the tip will check the pump and see maybe if the "blockage" is somwhere else as well. the washer tank is full from front so i doubt there is a leak, cant notice any wet paches but will check it all and see thanks for help well tank is full so the water is going into it, no leaks. the pump makes the buzzing noise I wonder if pump needs a replacement. anyone experienced this? Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted September 4, 2010 Take out the pump & check for blocked filter on inlet. Had this symptom (little water then none but pump still working) the other day in my E39. I initially thought my 18 month old pump had shat itself, upon removing it -found the blocked filter. Quote Share this post Link to post Share on other sites
skuter 0 Report post Posted September 4, 2010 Take out the pump & check for blocked filter on inlet. Had this symptom (little water then none but pump still working) the other day in my E39. I initially thought my 18 month old pump had shat itself, upon removing it -found the blocked filter. thanks for the tip will try that Quote Share this post Link to post Share on other sites
skuter 0 Report post Posted September 5, 2010 its fixed. I took the pump in the end and little grommet inside it. gave the pump few air blows and plugged it back in. Filled with water and its working nicely now. Thanks for you everyone helps, one less thing to worry about. Cheers, Ivan Quote Share this post Link to post Share on other sites
