curryinahurry 39 Report post Posted September 16, 2010 Hi, I've recently decided to change my parklights (the little ones inside the high beams) to white LED ones to match the colour of my xenons. But now the computer think the parklight has blown and lights up the indicator instead. Does anyone know a good way around this problem without switching back to those ugly looking filament parklights? THank, A Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted September 16, 2010 Yeap .. just a LCM recode ... Can help you out if needed. PM me Quote Share this post Link to post Share on other sites
rookie 0 Report post Posted September 17, 2010 (edited) Yeap .. just a LCM recode ... Can help you out if needed. PM me Hybrid, can the LCM be recoded for rear LED tail lights also? I had been thinking of replacing mine, but hadnt until i have gotten to the bottom of the whole error issue. I had read that only some of the newer years could be recoded? And not mine, a 2000 e46. Any ideas or knowledge ? Edited September 17, 2010 by rookie Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted September 17, 2010 Hybrid, can the LCM be recoded for rear LED tail lights also? I had been thinking of replacing mine, but hadnt until i have gotten to the bottom of the whole error issue. I had read that only some of the newer years could be recoded? And not mine, a 2000 e46. Any ideas or knowledge ? The LCM can be coded for the following Warning: High-beam headlamp Low-beam headlamp Front fog lamp Position lamp Taililght, outer Tailight, inner Number plate light Reverse lights Rear fog lamp, left Rear fog lamp, right Brake lights, left and right Brake lights, center Trailer lights Cold Monitoring: High-beam headlamp Low-beam headlamp Front fog lamp Front blinkers Rear blinkers Cold monitoring interval: in second Daytime running lights (DRL) DRL-ECE (Lowbeam + taillights) DRL-low-beam (no taillights) DRL-dimmed high-beam (no taillights) % Highbeam brightness (0..50%) What cant be coded at the moment is if you change out your park bulbs to LED or CCFL and trigger the side markers. You can trick the LCM by leaving one park bulb inserted into the socket and strapped in under the bonnet. Quote Share this post Link to post Share on other sites
bmwNewbe 0 Report post Posted February 21, 2011 did u get it sorted. basicly there is a cheat for this that does not involve leaving a naked blub tied up under the bonnet,that can rub onto wires plastic etc and can over heat. the trick is basicly a resistor and only costs a few pence, and the meathod is to solder it in between the positive and return just infront of the bulb holder and that feeds the correct resistance back to the lcm and tricks it to thinking all is ok. the only bad thing is that if the led side light fails you wont be told on your dash,but leds last for years and years so u should be good. Quote Share this post Link to post Share on other sites
curryinahurry 39 Report post Posted February 21, 2011 did u get it sorted. basicly there is a cheat for this that does not involve leaving a naked blub tied up under the bonnet,that can rub onto wires plastic etc and can over heat. the trick is basicly a resistor and only costs a few pence, and the meathod is to solder it in between the positive and return just infront of the bulb holder and that feeds the correct resistance back to the lcm and tricks it to thinking all is ok. the only bad thing is that if the led side light fails you wont be told on your dash,but leds last for years and years so u should be good. Hi, thanks for your reply. What resistance would you use? Would this be a high power resistor? Thanks, Andrew Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted February 21, 2011 Why not just code the LCM properly ? .. Quote Share this post Link to post Share on other sites
Yankus 0 Report post Posted February 21, 2011 What cant be coded at the moment is if you change out your park bulbs to LED or CCFL and trigger the side markers. You can trick the LCM by leaving one park bulb inserted into the socket and strapped in under the bonnet. Why not just code the LCM properly ? .. I think you just contradicted yourself there..... Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted February 22, 2011 I think you just contradicted yourself there..... What he means is although the car will not indicate an error on the dash, it would light up the side indicator to ensure the car's visibility on the road. So, to counter this, one will still need to put a load/resistance in the light circuit to trick the car NOT to do that. Quote Share this post Link to post Share on other sites
