cliffdunedin 8 Report post Posted November 4, 2010 Hey guys, failed on a WOF this morning on a few small things (fingers crossed and touch wood) 1 - brake lights not working...not a fuse so assuming a brake switch 2 - brake hoses perished...self explanatory but 3 - rear left seat belt not retracting...well it is, but not strongly!! This is what i can't figure out...how do i get too this? I had a quick net search but nothing. So hoping someone knows how i can get to this. Cheers guys Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted November 4, 2010 My E36 brakelights sometimes fail, try twisitng around the bulb holder or giving the contact points a sand before trying anything else. Quote Share this post Link to post Share on other sites
Sammy J 1 Report post Posted November 4, 2010 Pull the seatbelt out all the way and spray the top and the bottom with silicon spray, then work the belt in and out a couple times. Works a treat. Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted November 4, 2010 Awesome tip bro...worked awesome!! By any chance does anyone know how to get the brake switch out!? spent the last hour and can't get the bugger out. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted November 4, 2010 Was just going to suggest the belt lube thing. You can also sometimes correct it by blowing the whole belt with compressed air. Think from memory the brake light switch turns quarter turn to release. This is how it is adjusted for depth. These are common to fail - check if it has power going through it Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted November 4, 2010 I went to do that but...typical, couldn't find my multimeter Thanks for the suggestion, i'll give it a try later on! Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted November 4, 2010 (edited) yeah those brake light switch's are a bitch to get out, When i replaced mine i just ended up cutting the tabs on either side and pulled it out, The switch was stuffed anyway so was no point spending hours trying to get it out. From memory when putting the other one in push the white outer slide all the way in when putting it in. It should push up and clips in, Don't be afraid to use some force when pushing it up in there. Edited November 4, 2010 by M-Spec Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 4, 2010 (edited) Hey guys, failed on a WOF this morning on a few small things (fingers crossed and touch wood) 1 - brake lights not working...not a fuse so assuming a brake switch 2 - brake hoses perished...self explanatory but 3 - rear left seat belt not retracting...well it is, but not strongly!! This is what i can't figure out...how do i get too this? I had a quick net search but nothing. So hoping someone knows how i can get to this. Cheers guys You should know how to do all this... you know how to do everything else Edited November 4, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
Braeden320 0 Report post Posted November 4, 2010 (edited) You should know how to do all this... you know how to do everything else Aha-ha Gold! Edited November 4, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted November 4, 2010 You should know how to do all this... you know how to do everything else lolz. I did that silicone trick too, when the wof inspector claimed it wasn't working correctly when he'd accelerate, grab onto it and brake... Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted November 4, 2010 You should know how to do all this... you know how to do everything else What a good guy!! How long did it take you to come up with that!? All i wanted was some help with a problem (which i got)...not a smart arse comment from a mod... after all, isn't that what this forum is for!!! Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted November 4, 2010 Love your work Glenn, your very a' la' Paul Henry atm...saying things people have thought for ages Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 4, 2010 Love your work Glenn, your very a' la' Paul Henry atm...saying things people have thought for ages Probably get fired too Nathan Quote Share this post Link to post Share on other sites
