cliffdunedin
Couple of WOf issues.
Hey guys, failed on a WOF this morning on a few small things (fingers crossed and touch wood)
1 - brake lights not working...not a fuse so assuming a brake switch
2 - brake hoses perished...self explanatory
but
3 - rear left seat belt not retracting...well it is, but not strongly!!
This is what i can't figure out...how do i get too this? I had a quick net search but nothing. So hoping someone knows how i can get to this.
Cheers guys
My E36 brakelights sometimes fail, try twisitng around the bulb holder or giving the contact points a sand before trying anything else.
Pull the seatbelt out all the way and spray the top and the bottom with silicon spray, then work the belt in and out a couple times.
Works a treat.
Awesome tip bro...worked awesome!!
By any chance does anyone know how to get the brake switch out!? spent the last hour and can't get the bugger out.
Was just going to suggest the belt lube thing. You can also sometimes correct it by blowing the whole belt with compressed air.
Think from memory the brake light switch turns quarter turn to release. This is how it is adjusted for depth.
These are common to fail - check if it has power going through it
I went to do that but...typical, couldn't find my multimeter :angry:
Thanks for the suggestion, i'll give it a try later on!
yeah those brake light switch's are a bitch to get out, When i replaced mine i just ended up cutting the tabs on either side and pulled it out, The switch was stuffed anyway so was no point spending hours trying to get it out.
From memory when putting the other one in push the white outer slide all the way in when putting it in.
It should push up and clips in, Don't be afraid to use some force when pushing it up in there.
Edited by M-Spec
but
Cheers guys
You should know how to do all this... you know how to do everything else
Edited by *Glenn*
Aha-ha Gold!
Edited by *Glenn*
lolz.
I did that silicone trick too, when the wof inspector claimed it wasn't working correctly when he'd accelerate, grab onto it and brake...
What a good guy!! How long did it take you to come up with that!? :lol::rolleyes:
All i wanted was some help with a problem (which i got)...not a smart arse comment from a mod... after all, isn't that what this forum is for!!!
Love your work Glenn, your very a' la' Paul Henry atm...saying things people have thought for ages :rolleyes:
Probably get fired too Nathan :P
