NZPED 2 Report post Posted November 12, 2010 Hi, 1985 E30 318i A couple weeks ago my speedo started working intermitently and now its working less than 30% of the time. I have a feeling the problem is at the intrument cluster end of the system as initially I was able to tap the speedo to get it to start working again. Took the instrument cluster out today and blew everything out and wiped some dirt off the circuit board, reinstalled and speedo is still not working. Tacho, fuel and lights still working fine, is there somewhere i should take my instrument cluster for them to look at/ resolder? Quote Share this post Link to post Share on other sites
NZPED 2 Report post Posted November 23, 2010 BUMP, can anyone reccomend a good auto electrician on the north shore? Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted November 23, 2010 Have you looked at the speedo sender on the diff? unplug, and remove sender, clean all parts, reinstall and see how you go. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 23, 2010 Get Robinson Instrument Services in Sales Street to check the cluster first Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted November 23, 2010 I got a used cluster for 20 bucks on Trade me... they don't take long to swap. I just swapped my speedo over for the k's +1 to check the diff sender. Quote Share this post Link to post Share on other sites
