swordfish 30 Report post Posted November 23, 2010 Hello guys, Just wondering if anyone has ever used these? http://store.nexternal.com/shared/StoreFro...et=products.asp or these http://www.akgmotorsport.com/catalog/catal...sion%2FBushings and which ones do you think are better? Cheers. Quote Share this post Link to post Share on other sites
nipe 1 Report post Posted November 23, 2010 Solid metal ones are the best Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted November 23, 2010 I've got some powerflex ones that I still need to install. Will you be changing the diff bushes as well? I'm yet to decide if i'll solid mount it or not From everything i've read on the internet most urethane bushes are the same as the others. Only difference is that some use the factory washer/limiter underneath the bush. Others (not sure which brand) use their own washer/limiter that is known to not be as strong and bend around the nut and bolt. To fix this people have used a more thick washer. This requires using a larger bolt. Quote Share this post Link to post Share on other sites
