Eddie 66 Report post Posted November 25, 2010 I've got a 740i with the M60B40 After a bit of a thrash it now has no oil pressure. At first when it happened I turned the car off, then restarted it. It was fine for about 1km and then the oil warning came back up . Now the oil pressure warning is on all the time and you can hear that it has got little or no oil pressure. Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted November 25, 2010 Oil pump nuts are known for backing out of m60's just like on m50/2's But i'm not sure if that would explain the light going out when you were going again. Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted November 25, 2010 Can I get the sump off with the engine in place? Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted November 25, 2010 From this it looks like you can. http://www.cardomain.com/ride/240317/1996-...7-series/page-5 Hope this helps Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted November 25, 2010 Can I get the sump off with the engine in place?yes easy to sort just drop the lower pan from teh sump off . comon problem , loose bolts oil pump bolts . Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted November 27, 2010 Thanks guys- worked a treat. Clocked up over 200kms today with no problems Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted November 27, 2010 Had they backed out completely? Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted November 27, 2010 (edited) Had they backed out completely? one had fallen out and most of the others were loose Edited November 27, 2010 by rot62 Quote Share this post Link to post Share on other sites
