M5V8 337 Report post Posted November 26, 2010 On a trip north, stinking hot & what happens? Dam fans stopped! Nothing dead. All AC lights work, a small amount of air comes out but the fan is just not pushing any air! I found the fuses and they are fine. Think it maybe this final stage resistor I'm reading about Anyone else have the same? Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted November 26, 2010 On a trip north, stinking hot & what happens? Dam fans stopped! Nothing dead. All AC lights work, a small amount of air comes out but the fan is just not pushing any air! I found the fuses and they are fine. Think it maybe this final stage resistor I'm reading about Anyone else have the same? min and max only?? Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted November 26, 2010 min and max only??Narr nothing. All the buttons work but the fan doesn't blow.Best we got was a slight breeze at 100kph from just air forced in I think. I'm having to drive with the windows down. No warning at all totally out of the blue Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted November 26, 2010 Sounds like the blower motor has gone either that or the final stage resistor Quote Share this post Link to post Share on other sites
str8_6 278 Report post Posted November 26, 2010 Hey, try this link http://www.m5board.com/vbulletin/e39-m5-e5...ing-no-air.html Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted November 26, 2010 Hey, try this link http://www.m5board.com/vbulletin/e39-m5-e5...ing-no-air.html Yup. That sounds exactly like my issue.cheers fellas This is what my research was concluding as well. So strange it happened so suddenly with only80k's on the car. I guess it could happen anytime in that case. Bad timing it's a weekend and its freaking 28 degrees outside!! Quote Share this post Link to post Share on other sites
euroitalian 63 Report post Posted November 28, 2010 Make sure you check your AC cabin filters when you replace the resistor. Very important. Quote Share this post Link to post Share on other sites
myniu 0 Report post Posted November 29, 2010 more than likely your resistor failed..... same thing happened to my car as well..... since the summer is coming so i just had mine replaced early this month..... i suppose if you are good at cars... do some DIY otherwise there are heaps of places can do it for you in no time... Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted November 30, 2010 Make sure you check your AC cabin filters when you replace the resistor. Very important.Check for contaminents? yes I have already plus I think they are due for a change think i might get the car serviced before xmas just in case. Quote Share this post Link to post Share on other sites
