capacity83 0 Report post Posted December 14, 2010 Hey guys, I own a 2001 e46 320i sedan which just broke down due to a faulty MAF sensor. Just wondering what fits my car in terms of the MAF sensor. So my question is 1. Will a 98 320i MAF fit mine? 2. Im looking for the part number but im no mechanic so i dont really know how to remove the MAF to see whats under it and what ive search from the net is http://www.trademe.co.nz/Trade-Me-Motors/C...n-334807249.htm http://www.autopartsworld.com/bmw_parts/32...rflowmeter.html so is the part number PART # 13621432356 or W0133-1599645 Obviously i dont really want to spend up to 300-400 for the MAF (2nd hand) or 500 for a new one.. so what are my options? Thanks in advance Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 14, 2010 (edited) The car will not normaly fail to operate due to a faulty MAF. If the MAF is faulty you will need the exact same MAF by part #. Unplug the MAF and try starting it. If it won't start, the fault is not the MAF. Where are you located ? Edited December 14, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
capacity83 0 Report post Posted December 14, 2010 The car will not normaly fail to operate due to a faulty MAF. If the Maf is faulty you will need the exact same MAF by part #. Unplug the MAF and try starting it. If it won't start, the fault is not the MAF. Where are you located ? Hey glen, thanks for the quick reply, located at mission heights area near you. I did a diagnosis a few months back, had all sort of errors come up. However, ever since i changed the camshaft sensor, everything went away but one error. My mechanic says its the MAF that needs to be changed. Is this true? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 14, 2010 (edited) Let me check it for you tomorrow. I've just sent you a PM Edited December 14, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
HELLBM 1696 Report post Posted December 14, 2010 Can supply that maf OEM for $180. Regards Ray Quote Share this post Link to post Share on other sites
capacity83 0 Report post Posted December 19, 2010 Can supply that maf OEM for $180. Regards Ray sorted by Ray @ HELLBM. Thanks! Quote Share this post Link to post Share on other sites
