Jason407 0 Report post Posted December 23, 2010 Hi all. New member here, new to the World of BMW, and having problems with a 1999 540I, I'll elaborate in the maintanence forum. haven't had it long and it is over heating, have replaced the water pump, thermostat, radiator and had a cylinder leakage test done, no leaks found, pressure tested the cooling system, after an hour of holding pressure we gave up on that. Done a TK test on it, there was no exhaust gasses detected. If driving fast it stays cool, once we slow down, it over heats. Can anyone think of any other reason for the overheating? Quote Share this post Link to post Share on other sites
Guest Si Vis Pacem Report post Posted December 23, 2010 Hi all. New member here, new to the World of BMW, and having problems with a 1999 540I, I'll elaborate in the maintanence forum. haven't had it long and it is over heating, have replaced the water pump, thermostat, radiator and had a cylinder leakage test done, no leaks found, pressure tested the cooling system, after an hour of holding pressure we gave up on that. Done a TK test on it, there was no exhaust gasses detected. If driving fast it stays cool, once we slow down, it over heats. Can anyone think of any other reason for the overheating? Does that model have a viscous-drive fan? If so, check it by giving it a spin with your hand, if the fan spins freely then it needs replacing. Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted December 24, 2010 sounds like a problem with the fan yea. Quote Share this post Link to post Share on other sites
Jason407 0 Report post Posted December 24, 2010 Hi all, thanks for the fast reply, my dand and I are trying to fix this thing, we it does have a viscous fan, it was spinning but we have replaced it anyway, still over heats, I can't think of anything else except for pulling the heads but would like to avoid that if possible. Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted December 24, 2010 so it spins by itself? when the car sits idle and is hot does the fan boot up? Quote Share this post Link to post Share on other sites
Jason407 0 Report post Posted December 24, 2010 so it spins by itself? when the car sits idle and is hot does the fan boot up? Yes the fan spins slightly stiff, when the car is started the fan can be heard spinning hard and then slows down. It does spin when the car is at idel and hot Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 24, 2010 Does that model have a viscous-drive fan? If so, check it by giving it a spin with your hand, if the fan spins freely then it needs replacing. Wrong Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 24, 2010 (edited) Hi all, thanks for the fast reply, my dand and I are trying to fix this thing, we it does have a viscous fan, it was spinning but we have replaced it anyway, still over heats, I can't think of anything else except for pulling the heads but would like to avoid that if possible. Don't do that. Never , never pull things apart without diagnosing the exact fault first. Once dissabled you have no way of doing any further diagnostic work. You must diagnose the fault first. Do you have access to someone with a scanner, a BMW cooling system pressure tester ? Also check that the auxillary water pump for the heater system works and the electric cooling fan in front of the condsenser works at full speed when the engine gets too hot. Does the car loose water ? and have you checked that it is actualy overheating and not just a guage error. Has it been checked with an infra red thermometor ? Would also help if we knew where you were from. I can help after the 5th Edited December 24, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 24, 2010 the system may also need to be bled of air which can impede the flow of water Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 24, 2010 the system may also need to be bled of air which can impede the flow of water Sorry.. not correct unless the car has a problem. 1999 540 will self bleed if the auxillary water pump & duo valve system is working correctly and if it is done properly. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 24, 2010 Sorry.. not correct unless the car has a problem. 1999 540 will self bleed if the auxillary water pump & duo valve system is working correctly and if it is done properly.thats why i said may Quote Share this post Link to post Share on other sites
Guest Si Vis Pacem Report post Posted December 24, 2010 WrongThe master has spoken! Wrong why?Cheers Quote Share this post Link to post Share on other sites
polley 916 Report post Posted December 24, 2010 The master has spoken! Wrong why? Cheers Because that is not how a viscous fan works. Quote Share this post Link to post Share on other sites
Guest Si Vis Pacem Report post Posted December 24, 2010 Because that is not how a viscous fan works.Another one!For goodness sake you forum members, please qualify your statements/replies. This forum seems to be trending away from the informative, not useful at all. Quote Share this post Link to post Share on other sites
