Gus 5 Report post Posted April 16, 2005 does the stock e30 325i oil cooler have a thermostat? just wondering..... Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted April 17, 2005 No But if you don't believe me take a long hard look at the EPC Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted April 17, 2005 no, it dosnt. as the engine warms ups, oil pressure drops. but comes back up when reved. Quote Share this post Link to post Share on other sites
MattA 165 Report post Posted April 18, 2005 Yes.. If it's not a thermostat whats the thing that opens when oil temp comes up? as on mine oil isn't being pumped through the cooler when it's cold. It's the bit on the filter head often prone to leaking. I could be wrong but I bought a new seal for it from C/J BMW cheers Matt Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted April 18, 2005 basically what im saying, does oil flow through the oil cooler when its cold ie all the time, or only when i reaches a certain temp if its got more pressure when its cold tim, and less when warm would that indicate a thermostat? Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted April 18, 2005 when it heats up the v....(cant think of the word) of the oil changes. when the oil is cold. it is dense and think. when it warms up the oil increases in volume and becomes less dence. therefore pessure drops. that is my understanding. if someone can prove me wrong, i will stand corrected. Quote Share this post Link to post Share on other sites
CaM 0 Report post Posted April 18, 2005 when it heats up the v....(cant think of the word) of the oil changes. when the oil is cold. it is dense and think. when it warms up the oil increases in volume and becomes less dence. therefore pessure drops. that is my understanding. if someone can prove me wrong, i will stand corrected. word.... temperature rises, viscousity of the oil changes... laymans terms-it gets thinner.... harder for the oil pump to hold at high pressure as it escapes through oil galleries easier... Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted April 18, 2005 basically what im saying, does oil flow through the oil cooler when its cold ie all the time, or only when i reaches a certain temp Oil flow through the oil cooler on a 325 is thermostatically controlled (the valve is the thing under the oil filter where the pipes go off to the oil cooler) but a small amount of oil does go through even when the car is cold. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted April 18, 2005 basically what im saying, does oil flow through the oil cooler when its cold ie all the time, or only when i reaches a certain tempOil flow through the oil cooler on a 325 is thermostatically controlled (the valve is the thing under the oil filter where the pipes go off to the oil cooler) but a small amount of oil does go through even when the car is cold. Stupid EPC, it says nothing about it being a thermostat although i'm not surprised, I need a Bentleys.Does anyone actually have a spare mount - I need a new one, unless someone has a spare. Quote Share this post Link to post Share on other sites
