sxc_civic 0 Report post Posted January 2, 2011 i have a e30 coupe pulled the engine out straight in to the bin now all i need is to put a rb20 in it i have the complete halfcut... i need you guys to help with engine mounts gearbox mount, and also tail shaft and wiring.. please your help will be great.. thanks Quote Share this post Link to post Share on other sites
polley 916 Report post Posted January 2, 2011 You're gonna have to make up some engine and gearbox mounts. Or possibly you can find a place to purchase them. Quote Share this post Link to post Share on other sites
sxc_civic 0 Report post Posted January 2, 2011 ok weree do i get them ? or how to make them ? i need more info .thanks Quote Share this post Link to post Share on other sites
mark247 42 Report post Posted January 2, 2011 ok weree do i get them ? or how to make them ? i need more info .thanks Use google or learn to weld. I suggest google. Quote Share this post Link to post Share on other sites
sxc_civic 0 Report post Posted January 2, 2011 i know how to weld i need the measurments ... and info on what tail shaft and how diff is the wiring. thanks also cant find info on google i wouldidnt ask you if i had the info infront of me Quote Share this post Link to post Share on other sites
polley 916 Report post Posted January 2, 2011 You just need to sit the engine in there where you want it and then you can take measurements and make templates to make your own mounts. Once its sitting in there you can measure how much shorter / long the drive shaft needs to be and take it to a driveshaft shop and you can get them to shorten / lengthen it and put the nissan flange on it. You need to find wiring diagrams of your e30, and the car that your new engine came from, you can then play connect the dots with the wires. Here are some E30 wiring diagrams: http://www.armchair.mb.ca/~dave/BMW/e30/ Not many people have done this swap, so you are pretty much on your own to figure it out. Quote Share this post Link to post Share on other sites
sxc_civic 0 Report post Posted January 3, 2011 thanks, yeah i kno no 1 has done it but it always starts from some 1 ... will put pics up as soon as i start . Quote Share this post Link to post Share on other sites
Phatputer 3 Report post Posted January 3, 2011 As said earlier, go have a read around the net Here is a fella who did a full swap in RB20DET from fully stripped body through to completion. *you may need to be registered to view http://www.e30tech.com/forum/showthread.php?t=75962 Quote Share this post Link to post Share on other sites
