E30_318i 0 Report post Posted April 17, 2005 Yea today after cleaning the car both the driver side and passenger side floors was wet, moreso in the passenger, it looks to be running down the firewall and the corner of the trans tunnel then forming up at the bottom, on the passenger side anyway. At first I thought it was collant from the heater, but haven't had that on for about 3 weeks, and its been dry up to today. I read on another forum that it could be due to water tracks being blocked in the sunroof area? I can't see that causing water to leak from behind the dash/firewall though. Any thoughts? Cheers. Quote Share this post Link to post Share on other sites
CaM 0 Report post Posted April 17, 2005 leaking screen??? my ae86 sed to have this problem, but only on the passenger side... tuned out to be the sunroof drain pipes, they werent blocked, just didnt go into the sill far enough, so would kinda spill over..... my van screen leaks, should get it fixed.... got a few chips tho... hmm glass cover *smashes screen* :mosh: Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted April 17, 2005 Not sure on the 5's but check that the drain hole below the windscreen isn't blocked blocked. Next you'll have to pull up your carpets and check for rust in your firewall...is quite common but very annoying. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted April 17, 2005 I had this prob every time I washed my e30. was the drain hole below the windscreen that emerges in the engine bay on the drivers side from the firewall that was blocked allowing water to fill up below the windscreen wipers and enter through the aircon vents. As it was always dry there before, I didn't thoroughly check for rust as cam advises, but I have had the dash out and didn't see anything then, so should be sweet. Annoying, but easy fix. Presumably e34s are similar. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted April 18, 2005 as cam said the 5s have sunroof drains that if blocked cause water to pool on the floor....a fine fishing line is supposed to be the way to try an clear em.... Quote Share this post Link to post Share on other sites
Tommy 0 Report post Posted April 18, 2005 i,ve got the same prob but in the boot, as many e30 owners will know, wen the car it on a slight downward slope water builds up in the gutters around the boot and has no drain hole to let it out! So it just dribbles it into your boot. Anyone have a solution for this? Quote Share this post Link to post Share on other sites
E30_318i 0 Report post Posted April 18, 2005 Cheers all, will have a look in the weekend. i,ve got the same prob but in the boot, as many e30 owners will know, wen the car it on a slight downward slope water builds up in the gutters around the boot and has no drain hole to let it out! So it just dribbles it into your boot. Anyone have a solution for this? My old E30 had a leak from the tail light. I think the foam seal around it was f**ked. Quote Share this post Link to post Share on other sites
Tommy 0 Report post Posted April 19, 2005 I,ve seen it sitting there, it fills rite up wen I wash her. Quote Share this post Link to post Share on other sites
