my_e36 43 Report post Posted April 17, 2005 Hi everyone. Just thinking of getting a break upgrade but want to save money (like most of us here do). I am wondering, whether it make sense to buy a new, uprated front rotor, then shift the old front rotor to the rear. Since most fronts are bigger and more powerful than rear anyway. Also would like to know is it true that a LVV cert is needed for any break upgrade? Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted April 17, 2005 Best "bang for your buck" on a E36 would be to get the front brakes off a E46 330i (325x25mm) and the rears off a E46 328i (300x20) as they bolt straight on. You can also use E46 328i front rotors (300x22) with your stock calipers if you buy new carriers (the bit the caliper slides in) from a E46 328i. Quote Share this post Link to post Share on other sites
petone 0 Report post Posted April 18, 2005 (edited) Glenn, your using E36 front struts aren't you? Why did you go for the brembos instead of the upgrade you mentioned above? easier to find the brembos or better stopping or something else? Just interested... Edited April 18, 2005 by petone Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted April 18, 2005 Glenn, your using E36 front struts aren't you? Why did you go for the brembos instead of the upgrade you mentioned above? easier to find the brembos or better stopping or something else? Just interested... I'd assume it's because the brembos Glenn has are 4 pots and have far superior stopping power, not exactly the best bang for your buck like the E46 ones Shame it's not that easy to upgrade the E30 brakes. Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted April 18, 2005 true that, any e30 upgrade really needs to be 100% custom. like glenns old brakes. Quote Share this post Link to post Share on other sites
E34-535ti 5 Report post Posted April 18, 2005 I'd assume it's because the brembos Glenn has are 4 pots and have far superior stopping power, not exactly the best bang for your buck like the E46 ones No, it is because Glenn is a brake whore, there was nothing wrong with the old setup. I give the new setup 6 months max (from today, so prolly around 3 weeks of actual drive time) before it is upgraded.Actually, don't tell anyone, but I heard him muttering about leading 6pot calipers and trailing 4 pots on 355mm X5 discs for the front Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted April 18, 2005 No, it is because Glenn is a brake whore, there was nothing wrong with the old setup. I give the new setup 6 months max (from today, so prolly around 3 weeks of actual drive time) before it is upgraded. Actually, don't tell anyone, but I heard him muttering about leading 6pot calipers and trailing 4 pots on 355mm X5 discs for the front What a brake slut Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted April 18, 2005 :finger: Mike: I didn't think they'd cut it!! So I went bigger. The 330i calipers aren't very common in wreakers here yet, prolly get a pair out of the US/Europe easy enough. I forgot to mention the 330i 325x25mm rotors are only $125ea from BMW!! Quote Share this post Link to post Share on other sites
