tire
WTB: E28 / E34 M30 manual driveshaft
Topic changed. I have sourced a G260 gearbox from an M30 powered E28. I need the front half of the driveshaft because of the larger flange on the output shaft of the gearbox. Please get in touch if you have a spare
I don't want to just swap the flanges from an E30 G260.
Thanks
Max.
Edited by tastic
I recommend a JB racing FW - although it is expensive as you can see
People trying to help Max with this need to be aware that this is Bens old car and has the M10 gearbox behind the M30 which could be why this is giving problems for them.
hey max, didn't realise it was you on the phone, and I was hectic at the time
will call you back tomorrow with some ideas
wait till i"ve called you
Edited by Jono51
Cheers Jono!
Good to hear business is going well.
Edited by tastic
Flywheel hopefully sorted (just need to get it checked out by Bob), starter motor hopefully on the way, so I just need a clutch and PP.
Does anyone know if an M20 clutch & PP will work on an M30 flywheel? I was thinking about something like this http://www.trademe.co.nz/Trade-Me-Motors/C...n-348665447.htm
Edited by tastic
m20 clutch wont work on m30 flywheel .
m30 have a bigger clutch disc etc .
auto clutch in morning side have them and he can do beefier pressure plates etc fro a bit more
Ok thanks Brent. Doesn't look like Auto Clutch are open today.
Back on the hunt for a flywheel as it turns out the one I had was an M40 one.
Bump. OP changed. Thread recycling - save the planet.
Edited by tastic
