btccm3 1 Report post Posted January 26, 2011 so i got home from work the other nite and was idling while winding up the windows and suddenley the radiator split down the side on the plastic. so i was wondering what caused the spike in pressure? faulty thermostat maybe.... Quote Share this post Link to post Share on other sites
btccm3 1 Report post Posted January 26, 2011 im going to replace the radiator with a spare e36 m3 one iv got kicking around. i was thinking maybe i should replace the thermostat at the same time to be safe Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted January 26, 2011 pressuring cooling system..............gulp.(head gasket?) Hopefully its just old plastic...make sure the radiator is up to it,the m30 prollly requires more cooling than the M50???? Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted January 26, 2011 old age , plastic goes off. or maybe water pump or thermostat failure Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted January 26, 2011 Second hand radiator-bad idea!!! Quote Share this post Link to post Share on other sites
btccm3 1 Report post Posted January 26, 2011 pressuring cooling system..............gulp.(head gasket?) Hopefully its just old plastic...make sure the radiator is up to it,the m30 prollly requires more cooling than the M50???? really?because the s50 b30 one i have is much bigger. and the s50 produces much more power and im assuming that means more heat as a result thus the bigger core size. head gasket hmm didnt think of that ill have to make sure i check the water for traces of oil once its in. Quote Share this post Link to post Share on other sites
btccm3 1 Report post Posted January 26, 2011 so you do think if the thermostat has blocked the flow and presurised the system there is a high chance of it cooking the HG? Quote Share this post Link to post Share on other sites
btccm3 1 Report post Posted January 26, 2011 old age , plastic goes off. or maybe water pump or thermostat failurefingures crossed its just old plastic. Quote Share this post Link to post Share on other sites
btccm3 1 Report post Posted January 29, 2011 ive done it. It was super easy who would have known it would fit so well. so as it turns out the factory radiator in a 36 m3 sedan is almost identical to the 88 530 one it went stright in but is prob 20 cm lower along the bottom. i gave my 530 system and the s50 radiator a good flush seems to be all good now i think it was just old plastic prob solved. Quote Share this post Link to post Share on other sites
allan 295 Report post Posted January 30, 2011 Do not wish to rain on your success but I would be watching the whole set up very carefully for a while. Quote Share this post Link to post Share on other sites
btccm3 1 Report post Posted January 30, 2011 yeah iv been watching it pretty closely i did change the thermostat just to be sure and i removed the water pump and gave that a good clean too i redid the seal and the workings seem all good nothing was broken just a bit rusty but you get that with such a high k engine. Quote Share this post Link to post Share on other sites
