nzhaystack 0 Report post Posted March 15, 2011 Bare engine only, by this i mean alternator etc, cold air box etc wont be needed. Must be close to wellington with lowish km. Also must be in good working order. To suit: 1984 320i e30 Cheers Mitch Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted March 15, 2011 Do a skid Quote Share this post Link to post Share on other sites
Silvers13 0 Report post Posted March 17, 2011 you need to use fully ignition system converted into your 320i.K-jet tronic not a good idea for M20b25.buy an engine with loom is better.if from pre 87 325i.you need to drill two hole onto your bell houseing to match it. Quote Share this post Link to post Share on other sites
skidz 197 Report post Posted March 17, 2011 you need to use fully ignition system converted into your 320i.K-jet tronic not a good idea for M20b25.buy an engine with loom is better.if from pre 87 325i.you need to drill two hole onto your bell houseing to match it. Have a complete 2.7 shortblock, if you want, also have a good 731 head (tested etc, all Ok) which would all then be a bolt in job... Quote Share this post Link to post Share on other sites
