E36ShoppingTrolley 7 Report post Posted March 20, 2011 Hi There, My 1987 E30 325i has been diagnosed with big end bearing, and i am going to need a new m20b25, preferably with low kms and cambelt done. Cheers, Who would you guys reccomend for a cheap, good install? What other parts will be nessacary? Thanks Nick Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted March 20, 2011 Hi There, My 1987 E30 325i has been diagnosed with big end bearing, and i am going to need a new m20b25, preferably with low kms and cambelt done. Cheers, Who would you guys reccomend for a cheap, good install? What other parts will be nessacary? Thanks Nick Do it yourself. replace the cambelt before you install the engine... you'll want to do more than just the cambelt however. but it's all easy when it's out of the car... wish I did. M20 > M20 is pretty easy. Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted March 20, 2011 Do it yourself. replace the cambelt before you install the engine... you'll want to do more than just the cambelt however. but it's all easy when it's out of the car... wish I did. M20 > M20 is pretty easy. I can vouch for that. Some mates, some beer, and one day to do it in. Your set. Would also recommend thinking about doing the clutch while your in there. Wish I did haha. Quote Share this post Link to post Share on other sites
Phatputer 3 Report post Posted March 20, 2011 If you have a few days to take your time and potter away at the engine. While engine was out. Cambelt, tensioner, water pump and seals. Camshaft seal, crankshaft seal, intermediate seal Gearbox will also be out, so new clutch I pulled the flywheel off and did the rear main seal while I was at it. Exaust and intake seals as they are a shitload easier to do out of the car than in Pulled the injectors and cleaned them up / changed rubber seals as well. I also took the opportunity to spend some time cleaning 20+ years worth of crap off the engine. Basics however I would 1) Change cambelt, water pump and tensioner 2) do the camshaft seal while you can 3) adjust all your valves and replace valve cover gasket Quote Share this post Link to post Share on other sites
sascha 17 Report post Posted March 20, 2011 M50 it Quote Share this post Link to post Share on other sites
APT 205 Report post Posted March 21, 2011 How much do you have to spend ? Quote Share this post Link to post Share on other sites
Red Dwarf 136 Report post Posted March 26, 2011 You could always give Ray a ring at HELL BM... Quote Share this post Link to post Share on other sites
