polley 916 Report post Posted April 4, 2011 Wiring loom to suit e30 facelift and m50b25 non vanos. Was running in my car perfectly, which is a 89 facelift, no ABS. Loom has been stripped down and no longer has auto trans wires, diagnostics port or charcoal evap purge valve wires. Includes ECU. $150 for the lot. Be in quick before I chop it up and use it with my haltech. Quote Share this post Link to post Share on other sites
oscar90 0 Report post Posted April 5, 2011 anyone know if this would run a Pre-f/l?? or are there too many differences in wiring Quote Share this post Link to post Share on other sites
polley 916 Report post Posted April 5, 2011 The firewall / c101 plug is different. You can either add the required plug to the car side, or cut the harness side off and put the correct plug on that end. Quote Share this post Link to post Share on other sites
j_tomo 0 Report post Posted April 6, 2011 sounds like what I need, I can supply a standard e36 loom if wanted Quote Share this post Link to post Share on other sites
polley 916 Report post Posted April 10, 2011 Bump. Cutting this up in a week or so if it does not sell. Quote Share this post Link to post Share on other sites
hybrid 1044 Report post Posted April 10, 2011 Pre-facelift body loom is quite a bit different than facelift. The unloader and starter circuit is different as with the fuse box etc. It is possible to mix and match but requires rewiring of pinouts. Quote Share this post Link to post Share on other sites
oscar90 0 Report post Posted April 10, 2011 Thanks for that Josh, Will be easier to start fresh and let someone use this as a plug in option. Someone buy it!! Quote Share this post Link to post Share on other sites
polley 916 Report post Posted April 10, 2011 Will throw in the MAF aswell. Needs new mesh on one side (just clips in) Quote Share this post Link to post Share on other sites
