pureboiracer 0 Report post Posted April 25, 2011 (edited) Ok so here is a list of what i need so far, (will update in time.) pre facelift 320 body loom. (complete from headlights to tail lights, do not need engine loom) Pre facelift heater box, (im not sure if they are different from facelift ones. Steel brake lines running down the rear trailing arms for a disc rear end, also need both front brake lines that go from the m,cylinder to the wheel arches. an open 4.1 ratio diff. Thats all i can think of for now, any help with this will be much appreciated. Cheers oli Edited April 27, 2011 by -Oli- Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3034 Report post Posted April 25, 2011 I have a couple of boxes of loom from a pre-facelift, I think it is all there. Also have the fan / heater box and loads of brake lines (not sure about the rear trailing arm ones tho') if you are interested... Would be willing to let the go for cheap as you're such a good b'std Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted April 25, 2011 ^will be in touch buddyo Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted April 25, 2011 (edited) am going to strip my e30 so will have the brake lines available locally soon. can have them if you want, i wont be bothering trying to sell them. also have a facelift loom if your keen Edited April 25, 2011 by _Ethrty-Andy_ Quote Share this post Link to post Share on other sites
Jono51 60 Report post Posted April 25, 2011 Ok so here is a list of what i need so far, (will update in time.) pre facelift 320 body loom. (complete from headlights to tail lights, do not need engine loom) Pre facelift heater box, (im not sure if they are different from facelift ones. Steel brake lines running down the rear trailing arms for a disc rear end, also need both front brake lines that go from the m,cylinder to the wheel arches. an open 4.1 ratio lsd. Thats all i can think of for now, any help with this will be much appreciated. Cheers oli gidday Oli pop in mate, wrecking out an E30 at the moment with lines Quote Share this post Link to post Share on other sites
